Wouldn’t that be great! Think about it, if all those lines were on the floor before you started installing your tile, how easy would it be to figure out your cuts for the tile and then install the tile using those lines to guide you? Wouldn’t almost be like cheating? Well I’ll tell you first hand, that this is the process I use and IT WORKS GREAT! There are a few simple steps that we will go through, then you can use this system too.
